·Hello all, I'm new to the forum.
A little about myself... I'm from northern california.. I've had a 1969 mustang Mach1 since I was 16 (21 now).
I don't drive it that much because it has had quite a few problems since I've had it (it was my moms before mine, but she didn't drive it for 10 years).
Work was done to it, but I'm not sure what all was done.
I do know that the rear end was re-geared, but I honestly couldnt tell you what size...
I had the engine rebuilt when I first got it and the guy who did the rebuild did a really bad job on it. The bottom end was "new" or so he said but it overheated after driving it for about 10 minutes.
Later I found oil in the radiator and no one could figure out where it was coming from.
The heads were pulled off, gaskets checked, block dyed and checked etc... but nothing solved the problem.
We had the radiator flushed mutliple times but the oil kept returning.
Finally after about 4 years of deliberation with this mechanic he gave in and said he would do the rebuild again, including another new bottom end. So he did.
It took him about a year to finish because business was slow and he didn't have the money for the parts.
I just got it back about six months ago. The oil leak is fixed, we figured it was a crack in the block some where that was just not found. But the overheating persists, it just takes longer.
Things will happen such as... the idle will drop very low and the car will die at stopsigns/lights.
I'm not looking for all the answers, I'm just looking for a place where I can talk about my car with other people who know about mustangs (as I don't).
Thanks... Mike
and here's a link to some pictures.
Mike's 1969 Ford Mustang Mach1
(the are on a honda forum because I work with honda's a lot more than I work with fords, but I've got both so I figure I should learn.)
Thanks... Mike
