·Just got my 67 Fastback (390, auto, 389 traction-lok) on the road for the first time. The rearend is making a loud howling/ vibration noise at cruising speed, it pretty much goes away when I let off the gas or accelerate. I've been told many different causes from worn bearings to- the gears not being set up properly to- the nut on the universal flange not being tight enough which would cause the gear setting to be off. If the gears are too badly misworn I'd really like to go to a set of 3.50's. Any input or advice would be appreciated. Thanks.
67 GTA 390 Fastback- Moss Green
Deluxe black interior.
