ok replaced the alternator after a failed cruise on saturday nite which resulted in running off the battery, new alternator this morning runnning good take another cruise get home engine dies no spark at the coil, could this be a voltage regulator or simply as it is a coil????
thanx
Gone but never forgetten
Use a volt meter and see if you have voltage to the + side of the coil with the key in the on position (hint: only leave the key in the on position JUST long enough to check for voltage, or it can damage points, coil, and/or a Pertronix Ignitor).
If you have ~7v or more, it's probably the coil or a problem with the distributor (points, sheered roll pin, bad magnetic pickup on an electronic module, etc.). If you don't have voltage at the + post, look for problems with the ignition switch and related wiring.
