21 - 34 of 34 Posts
1966 v8/T5/9" swap in progress
I thought my battery tender died recently after if failed to charge two batteries that sat all winter. However, it was not dead. It turns out there is a minimum voltage needed in the battery for the tender to charge it. I was able to save the batteries and get the tender working by first using my NOCO Genius to bring the battery up past that minimum level. After that, all good.
That's why I never throw them away. Sometimes it's hard to tell if it's the battery or the charger. If I get time I'll test my two "dead" ones more thoroughly.
I've dealt a lot with motorcycle batteries. Now imagine something that is basically a 50-100 year old design but the quality is worse than ever somehow and that's a lead acid motorcycle battery in a nutshell. Really makes you wonder about your charger when a new battery won't take a charge, but it's probably the battery. I stopped messing with them and put a TruGel in every motorcycle immediately when I get it.
I won a special award
Harbor Freight NOOOOOOO...🤫
Do you have a story about them? I have no experience with them, but the cost of a tender that only lasts a year....it would be worth the gamble to me....plus HF is getting better quality stuff...the 40 dollar "VIKING" charger does alot...I am curious as to your experience...if no experience...that's cool too.
I have a story about a HF charger and the battery it killed. It's not a cheap story either since it killed a 27 series deep cycle battery that was only a year old. It over charged the battery and was boiling the cells. I chucked that P.O.S. HF charger out and moved over to Deltran Battery Tenders about 8 years ago. I think I have 4 or 5 of the Deltrans now. I use one on my Ford Super Duty diesel to keep the dual batteries up during the winter when I don't use the truck much. I have two chargers for my RV batteries. I use one charger on the AGM battery for my Mustang. No issues whatsoever.
1967 Coupe
I used Battery Tenders to charge my motorcycle and lawn mower batteries and had no issue.
Got a NOCO genius for the Mustang battery. I believe it is a better product.
A certain big box Auto did not want to honor the warranty on a battery. I told the Manager my NOCO genius will only charge it to 75%. I got a replacement battery.
I have three - one died after I dropped it pretty hard - worked a bit intermittently, then died 100% I like them a lot, still!
Last week my Battery Tender was connected to my Mustang's battery and working fine. I disconnected it to pull the car out the garage. I pulled it back in and forgot to reconnect the battery tender. A few days later I went to reconnect the Battery Tender and it was completely dead. No lights. Nobody home. Nothing.
This Battery Tender is less than a year old. Has anyone had a similar experience? Not sure if I should buy another, but I also don't know of any alternatives.
Thanks.
That is usually what happens with these types of things. They work fine until they don't. I have not heard of very many of these failing but have known of a few that did not last long.
I actually have this Viking charger/tender and it works great. I got it for the lawn tractor and just because its nice to have more than one battery charger. I have a Schumacher for the primary one. I like its features and display. For what it is I bet it is just as good as a Battery Tender. As far as Harbor Freight's bargain basement battery maintainers go I tried one of them a few years back and they never shut off so you can't trust it in my opinion. I wouldn't have a lot of trust in their basic charger either.
4 Amp Fully Automatic Microprocessor Controlled Battery Charger/Maintainer
798565
I've seen that some newer Corvettes came factory with what appears to be a NOCO battery maintainer. I've heard nothing but good things about these chargers. It might be the next brand I buy.
I failed to disconnect my weather proof Battery Tender on the. motorcycle one morning and dragged it 6 miles to work. The BMW rider that got in after I did kindly placed it on my seat. Six or so years ago and still working. Just glad it didn’t get tangled in wheels or chain.
I have two NOCO genius tenders. One is a newer model which hasn't had much use. The older one I've had for 8+ years and works great.
I should really start using them again. I get nervous leaving them plugged in at my shop. I've read a few horror stories about tenders starting a fire.
Anyone else here this? The NOCO have an inline fuse.
Sent from my Moto E (4) Plus using Tapatalk
I've been using two of these for a few years. It's a knock off of the NOCO. I got them for $15 each on black friday a few years ago.
Vector 6-Volt/12-Volt Battery Portable Car Battery Charger and Maintainer-BM315V - The Home Depot
The only thing was the ring terminal connectors have too much heat shrink on them and prevent a good connection when attached to the terminals, so I had to trim that back carefully with a razor knife.
I used to have the Harbor Freight "battery tenders" and I think they weren't that great. I got rid of them.
I also have an old Schumacher 1 amp motorcycle charger that always worked great, and I still use it for "loose" batteries that don't have the dongles on them. This is what I used on my International Scout for 20 years and the batteries all lasted 5 years or more.
Jason
21 - 34 of 34 Posts
