i have a 68 i believed they called them slotted steel rims you know the ones with the 7 inch center caps this are 14x7 with i think a 4 inch backspace. i want to use a b.f. goodrich radial ta tire what size can i put on the rim to make it look good you guys know what i mean
and yes i did you the search
i only found one listing for 67/68 and it was not the info i needed ::
chris
If it helps, im running P225-60-15 on 15x7 Cragars with 4 1/8 backspacing
Stock height, no rubbing -even on the biggest potholes! ::
Gary
