Would you walk on a 16' platform made from 3 2" x 6", 12" on center and 24" wide covered in 3/4" plywood, all screwed instead of nailed? Would it be rigid enough walk back and forth on while siding the second story of my garage? Should I use 2 x 8 instead? What ever I use/buy will become my workbench and shelving. I had originally ordered a set of Werner platoforms, but at 490.00 each and needing 2 of them, the cost was a bit out of touch for a 3 day job (I hope)and no future use ideas except to put up Christmas lights.
If they were continuous 16' 2x6s with lateral buckling support in two equal spacings and boxed at the ends, I would. This is assuming you are supporting at the extreme edges of the platform.
just covering the top should suffice
I should ask if its just goingto be you, or what else is going up there. 2x6 may be a little soft, it will hold you, if theres going to be more i would go 2x8.
Two word answer: "Think Rental Equipment." - OK, three words. Our local "Rentz-All" has scaffolding, and that is the option I intend to go next spring when siding the upper areas of the house.
Discussion Starter · #6 ·
It will just be me. Chances are I'll just go with 2x8 just because I can make some really nice heavy duty workbench tops. :)
I tried to go the rental route, but I already own the pump jack system. I got overzelous. I tried to rent, but no one in the area (chicagoland) rents the 16' platforms to put on the system or they are all out until next year!, so I am forced to build my own. Regular scaffolding would not work, and a tower of the width I'd need to rent would be about 200 for the weekend, the wood would be less than 50 and still be useful when done.
