Not sure if this is normal or not:
After tuning my 69 302/4v I'm getting a slight throaty kind of noise upon deceleration in the rear of the muffler. It's not really a backfire and only happens when dropping from about 2500rpm-650rpm usully during a gear change. Any advice would be appreciated, cheers, Rob
Running a little rich? To much unburnt fuel in the muffler will cause that.
New plugs, points, condenser. Checked gap, dwell, timing set at 6 degrees BDC, idle at 650rpm. Idles fines, maybe I should check:
¥ for vacuum leak at carb /advance?
¥ leak in exhaust headers (er, how do I do this?)
¥ for too lean an A/F mixture in secondaries, the adjustable screw nearest the choke, yeah? (Edelbrock 650 Performer 4v)
Any other ideas?
Just for the heck of it, raise the idle speed up a little and richen the idle mixture just a tad...see if that helps..
When you romp on it, any pinging? If not, try advancing the timing, a little at a time, until it pings, then back it off slightly. Re-check for the noise...
My instinct is that one or both of these areas will contain the answer to your query...
thanks, I'll try raising the idle speed up a little. and adjust for a slightly richer mixture. No pinging when running 91 octane watered down CA gas /forums/images/icons/wink.gif I'll advance the timing if the carb fiddling doesn't work.
