1 - 10 of 10 Posts
I have an OEM style Rally Pack that hooks up to the pink wire by the ignition. I need to update my dizzy and electronic ignition to a pertronix dizzy setup. Is there a way to make the tach work with it?
Ok, I guess you know the Pertronix has a red and brown wire. The red gets a dedicated switched 12V feed. the brown is connected to the trigger lead, I think it be your black/red or blue/red? Pertonix's directions should clarify. Also, know your tach is a current sensing tach, and connected "inline" with "run" side of your ignition switch. Like most of that era were, until the early 70s, converted to what was/is known as voltage sensing and were attached to the negative side of the coil in some way. At least I think this be correct recall. Other members will weigh in. I don't see you having any problems with your RallyPak, until you attempt to add a CD ignition box. This, is when electrical/electrics get crazy with the RallyPak.
I have a OEM-style rally-pac and a petronix 1. There was no special wiring involved. Wire the rally-pac per the instructions, and the petronix per the instructions. Mine works fine.
I guess I should have said original wiring OEM style Rally Pack or a replica. Others such as the Scott Drake will work. Do you know if the one you have is wired as the original was?
Sure. Leave everything connected exactly like you have it now, and simply pull a fresh 18ga primary wire from your ignition switch "C" post out through the firewall connector (there are usually a couple blank spots... butyl-glue in a bullet connector in each half...) to connect to your Pertronix's red wire. Too easy-peasy.
Thanks Woodchuck.
Here is the dizzy I have coming.
Thanks Woodchuck.
FWIW, the IgnitorII is the most trouble-prone of all their modules..... Also, if you have a flat tappet cam in your car you're going to quickly chew up the distributor drive gear since the distributor you ordered has a steel gear.
If you simply want to ditch the points and have a decent solid-state ignition you could go with a DurasparkII distributor triggering a Mopar ignition box and the whole set-up, even sending the distributor to Dan Nolan to have the advance curves blueprinted, will set you back less than the over-the-counter Pertronix...
Discussion Starter #8
I'm running a Duraspark II now and am having some sort of issue where when the secondaries open it is falling flat on it's face. I was using a 570 Street Avenger and now a 650 Edelbrock AVS. Plenty of fuel pressure with the Edebrock hi flow pump too Thinking it's in the timing advance curve now. I didn't install the Duraspark II dizzy and module I simply reused it when I had the motor rebuilt.
It is a roller motor, however I didn't change the original Dizzy gear which was the Duraspark II when I switched over from flat tappet to roller. Hopefully didn't hurt anything for the limited amount of time it has been in the motor.
If you're NOT running a billet-steel roller cam, like the OEM Ford or Ford "letter" cams then you should be fine with a cast iron distributor gear. What roller cam are you using?
Discussion Starter #10
Using a Lunati EFI compatible 218/218 112lsa .525 lift. 351w firing order. Nothing to radical.
1 - 10 of 10 Posts
