I was installing a shift kit in the Stang today. Except for the mess, it was going pretty good. It was alot easier than I had anticipated. Anyway, when I was torqueing down the valve body bolts SNAP! one breaks off. Luckily, it broke off at a point where I just removed the valve body and could take the bolt shaft out by hand. So, now I have to see if I can't find a replacement bolt somewhere tomorrow. Wish me luck! Update will be tomorrow.
Beware when things are going too well. That's when things seem to go bad. Good Luck tomorrow!
http://a1.cpimg.com/image/9B/78/15534491-cad9-02000180-.jpg
IIRC, those bolts get very little torque, much like intake manifold bolts.
In your shoes, I'd probably tighten them down with a 1/4" drive ratchet, holding it for very little leverage.
The kit says to torque them down to 80-120 in-lbs. I didn't have any problems with any of the other bolts. Oh well.
Yeah I do realize that almost everyplace around here will be closed tomorrow, but hopefully I will be able to find something somewhere.
Don't do like I did once and misread "in-pounds" for "ft-pounds." :eek:
