Any one have a sugestion on how to get the oil dip stick tube out of the timing chain cover. The tube snapped off rigt at the point where it goes in to the timing chain cover.
I'd try an easy-out first. If not, you'll have to drill it out. If you do, you should take it off the engine first. I've gotten them out both ways...
Had the same thing happen and I drilled it out.Made a new one useing the 3/8 metal gas line.Works good, fits in the hole tight and easy to bend.
Don
