Does any one have any experience with finding oil in the in the intake manifold and carb spacer on a 1966 289 4v motor. I cleaned out the carb spacer before putting on the rebuilt carb. I replaced the pcv valve and hose to the spacer. Both sides of the intake dual plane manifold are getting oil in them. The car is starting to smoke a lot. Any help would be great.
:eek:sounds like you got some blow-by ie bad piston rings but without doing a wet and dry compression test its hard to tell. gl. ::
