Well since it looks like Sept 6 works for most, I'll be glad to have anyone who shows up ::.
As for tools, I have a 1 set up cheap spring compressors; if someone has a better option bring it. I know Cloney's caster/camber tool will come in handy. Any other implements of construction/destruction should be welcome. I should have most necessary tools, but then again maybe I don't have the correct tool for the job :p and I learned to work around it.
As before, refreshemnts will be provided.
hey alan even though i probably cant make it on the 6 th my tools are still availably.i have a heavy duty floor jack if needed and four heavy duty jack stands.let me know if you need any of it. also i would be available after 3 or 4 p.m. on the 6 th . if you think youll still be working on it then let me know although it sounds like youll have enough chefs in the kitchen.
You're welcome to come over, hopefully by that time we may be to the refreshment stage. But you never know
