1 - 1 of 1 Posts
I have a 72 mustang convertible with a "Q" code 351. I have idiot lights {oil,temp,brake,alt} The alt works on startup because its on its own wiring system. But the other lights won,t work {light up}, I tested the oil sender and it seams to be open with the engine not running and the same way when the engine is running. Bad sender? but that won't explain the lights. They should come on momentarily on the instrument panel when you turn the engine over along with the brake and temp lights, and the light bulbs do work, I tested them. Is there a fuse or a circuit breaker, I checked the fuses and they all work. Is there one common hot wire that feeds all these lights?
1 - 1 of 1 Posts
