Can somebody tell me if an original engine makes the car any more valuable? Also one of my Mustangs used to have a 6 cylinder in it, if I put a V-8 in it what will I need to change. Thanks.
Seth
Banned
Depends on what the original engine is, and what the condition of said engine is. For example, an original "K" code engine in poor shape would be worth more than a replacement vintage pristine "C" coder. But that replacement "C" would be worth more (to most people) if it were replacing a poor conditional original "C".
As for the V8 swap, try the search of the forum, it's been discussed before.
Steve
I think it is up to the buyer and thier purpose. I prefer and original and non-rebuilt engine only because I can't tell if it was done 'right'. I would rather be involved in the re-building. I have the same feelings regarding a I6 to V8 swap.
My plan is to have one original car and one very updated restomod.
Banned
Short list of things that will need to be changed:
Motor mounts (metal frame brackets in addition to the rubber mounts)
Radiator
Rear end (to do job right, you will KILL the 6 rear)
Tranny (again to do it right)
Front end
Driveshaft
Exhaust
Unless you already have a wrecked V8 car as a donor, I wouldn't attempt it.
there is tons of info on the swap here, do a search.
i did a swap, and all i can say is, don`t do it without a parts car to both scavenge, and see how things went together
