· Registered
I have a 351W - 2v with an FMX tranny...I want to stay automatic but I'm thinking about wanting an overdrive...what can I do? Do I have to replace the tranny with an AOD tranny? What kind? From a 87 'stang for instance? I'm considering the option and would like to know any and all advice and opinions. Thanx! Guy(NH)
'69 Mustang Grande
351W - 2v - FMX
· Registered
The June 2001 issue of Mustang Illustrated has an interesting
article on a bolt-on over/underdrive transmission which will
convert your C4/C6 (and presumably FMX) into (effectively)
a 6 speed AOD. It's not the cheapest alternative, but it is
transferrable from car to car so you can hang onto it if you
ever sell your ride.
http://www.gearvendors.com/
Rich
'67 C-code 'vert (Dees67)
'69 GT FB (project car)
Check out my band: Brickyard Blues
I'm in the process of doing a C-4 to AOD (90 GT mustang) conversion. If you go to the old forum and do a search will find alot of info.
Here are a couple site that will give you an idea of what you need and the pricing of parts.
NPD and others also have conversion parts.
http://www.baumannengineering.com/aodeupgr.htm
http://www.windsorfox.com/
Drew
66' 289 2v, C-4, bench and a/c
http://albums.photopoint.com/j/View?u=1594736&a=12147274&p=44139589.jpg<P ID="edit"><FONT SIZE=-1>Edited by Drew66 on 04/03/01 03:29 PM (server time).</FONT></P>
· Registered
YOU CAN USE AN EARLY 80's NON ELECTRONIC AOD IT USES A LOCK UP CONVERTER AND STILL WILL BE ABLE TO USE YOUR STOCK 1,2,DR, 3 SPEED AUTO SHIFTER ALTHOUGH TH S IS NOT A PERFORMANCE PEICE, THE 81 LTD USED THIS TRANS AND LOTS OF CUSTOM MERC GUYS USE THEM..BY THE WAY I'LL MAKE YOU A GOOD DEAL ON ONE OF THESE I WAS GOING TO USE IN MY F-100.IN OHIO..
· Registered
Discussion Starter · #5 ·
Thanx Dees, Drew and Chromedaddy on the information and links...it's something that I will look into doing...Guy(NH)
'69 Mustang Grande
351W - 2v - FMX
