·:: Our early '65 convertible overheats. It has a new thermostat, radiator is ok, water pump ok. The freeze plug was pulled and some sludge was found, not much. Car still overheats. Help!! Any ideas why????
When you say it overheats, are we talking coolant spewing out the overflow and getting really hot, or is the gauge just running a little further over than you would like. It could be that the gauge is just off. Unless it's getting REALLY hot, I would first verify the gauge with a good mechanical one....radiator is ok, water pump ok. The freeze plug was pulled and some sludge was found...
