Have you done a search here? This was talked about not long ago...Good Luck
I'm just curious if you've decided on what paint to use on the hood? I'm thinking of just trying the Krylon 1613 dry spray method.
If you use the spray bomb paints buy a bunch of it or never wash it and keep it out of the sun 'cause it will require repainting otherwise. I used a spray gun chassis black paint that requires hardener which will not fade like the rattle can junk. It matched the original Ditzler stuff used by the factory
Scott, I was up your way this past weekend. I remembered too late (right before reaching the intersection of 9 and 202) that I should have given you a call. Can I assume the restoration shop is getting ready to do the detailed painting? If so, does that mean you'll be getting the car back soon?
