1 - 9 of 9 Posts
Only prep I know is, clean, clean, then clean more. The tape off anything you don't want paint in or on. I used Dupli-color engine enamel primer and dark ford blue. Came out pretty good. Don't know about the clear though, I thought that stuff would yellow after a bit.
Ditto for the clean and clean. I primed mine with red oxide rustoleum out of a can then Ford Blue out of a can. 10 years later, still looks good.
Like they say get them clean. Prior to painting mine (it was bare) I used my spray gun filled with lacquer thinner to clean the bock and heads. Immediately afer I painted it with rattle cans, no primer. Its been 4 years, 5K miles no problems.
Dan
You don't need primer with engine paint. Don't use it. I powerwashed mine real good and then soaked it with oven cleaner over night, powerwashed it again. Worked well and was easy. Don't get oven cleaner on your aluminum/chrome.
In case anyone else is interested this is the info I passed along to copasspupil.
"I spoke to Dupont regarding painting the engine. They have a DTM (direct to metal) primer that you can spray directly on the engine after thorough cleaning. I used the same BC/CC that I shot the car with. They also recommended that I use just enough paint to cover instead of multiple coats because the thicker the paint the better chance of it cracking due to expansion and contraction. Hope that helps."
Just to add something to the good suggestions so far, if you are going to paint with a rattle can use many, many coats. I did 6 coats and wish I would have done 10-15. The paint was not very durable with only 6 coats. I'm rebuilding the engine this winter so when I repaint it, it will get 15 coats.
I epoxy primer my engines before I paint them. I use the good ppg DPxxLF primers. Then you can topcoat with any color you want.
1 - 9 of 9 Posts
