Hi VFM'ers. Still working on my paint prep. I got my top loader upgraded to a 5 speed and when the shop installed the hydraulic clutch it went into the space where the parking brake meets the firewall. Now the parking brake handle is not perpendicular to the dash. Here is a photo.
Has anyone dealt with this?
Thanks in advance.
756469
Rodney
The shop that did the work. There is the problem. The job was to install the hydraulic clutch and nothing else. DIY I say.
That was sort of my question. There doesn’t seem to be room for the parking brake and the clutch mechanism. maybe I could move them myself if there was a way they could both fit. This is modern drivelines kit.
What year? MDL kit. We are not mind readers! You can add info in the signature portion of your posts. It helps a bunch!
756518
I never touched my e-brake when I installed the hydro clutch on my 65.
You mean the bracket that attaches to the dash is now rotated counter-clockwise?
756527
I'd remove the handle and disassemble, then slice off the bottom about 1" up the tube, rotate it to the "correct" position and use a short sleeve to attach the 2 pieces back together. Way easier than trying to undo the upper end.
Sorry been away from VMF for a few months and just getting used to the new look and how to post photos etc. Don’t know how the unicorn got added. The problem is the parking brake got moved to the left where it meets the firewall and now looks ”crooked“ I.e. rotated counter clockwise. There isn’t room to move the handle left because the shaft will hit up against the fresh air vent. I will have to find the manual for the kit. Sure I have it somewhere. This is a 67 coupe that may have been automatic at birth.
did you mean “slice“ off the tube and reattach?
You mean I DIDN'T type "slice"? Keyboard cramps. LOL.
