So I'm replacing the parking brake cable from the equalizer back.
Any tip or tricks for the install and how do you set/adjust it?
replace your cables 1st, starting at the drums. Run them forward to the connector at the pivot bar, and snug the nut up. You want just enough tension on the cables so that they're tight, but not engaging the brakes. Make sure your parking brake lever is not pulled- that it's seated full in the 'off' position. When you're done, test it and see how it works. If it doesn't hold the car, snug it up a little and recheck again. Repeat as needed
I have just done this adjustment on my '66 Fastback. I've attached the adjustment procedure out of the Shop Manual.
Discussion Starter · #4 ·
Thanks!
I figured it was in the shop manual.......I'm just feeling lazy and didn't want to read when I get home!:grin2:
