1 - 13 of 13 Posts
In trying to install my exhaust, I found the notch in my e brake bar will not stay in place it slides out. does this look correct?
799171
799173
Some of the stuff is OE others are not ? Probably the problem. Brian
Mine will do that if the rear cables are too slack.
It looks right to me but the 65 setup is slightly different where the cables attach to the adjustment/tensioner.
Different year but similar... Where the heck is your RIGHT cable going?
799256
Discussion Starter · #12 ·
In the photos it looks like both are headed to the left rear.
It's the angle! I assure you they are going to the opposite sides, but I was wondering if the solid part of the u bracket should be up instead of down. thinking that would raise that bracket maybe a touch and allow clearance for my X pipe.
1 - 13 of 13 Posts
