Does anyone know where to get two new air bleed needles for my 65 autolite 4100 carb? I also have to set the float adjustment , can anyone post some useful info on the float specs or where to get simple small parts like that.
Steve Stiles
64.5 Mustang Coupe 289 4V Autolite 4100 600cfm.
c4 8inch 3:00 gears
Take a look here
You can contact Pony Carbs with the details of what you need if you don't see it...
To be honest, the last time I looked inside the 4100 on the D-coder, it appeared the float assembly was just level...I haven't adjusted it in the 9 years I've had the car. Most rebuild kits come with a guage or instructions (at least they used to *G*)
Good luck!  †
You caught me in the middle of one of those " make 1 good carb from 5 different carbs weekends". Actually was able to build a good C5ZF 4100 Carb. In the info gathering stage of the project I found these two web sites that were pretty infromative. Will use Cfiworld to buy some parts to finish another one. Hey, 2 out of 5 would be pretty good
I haven't bought anything from theses guys yet, but they have a pretty good site. Wait for the "splash screen" to load,click "enter",then "everything carburetor", then "ford" , then "4100". As you page thru the pop up there are set up tips and also a list of single parts with pics available that you can order. There is also an carb adjustment spec page.
http://www.cfiworld.com
Also, this is a infromative site. Ford carb Forum.
http://www.network54.com/Hide/Forum/88781?it=0
Good Luck,
