I need to know where the hose for the PCV valve connects to the engine. I have a 65 289 K code but the engine has a Cobra intake and a holley carb. When I got the car there was just a plastic elbow on the valve cover and the hose went to a fitting on one of the intake runners (NO PCV valve). Is this correct? I was told I really should use a PCV valve and it would be better to run it to a spacer plate under the carb. What was the setup on a Shelby?
