My plugs are gapped at .035" but I've heard that they should be opened up to about .040-.045. I'm using the Pertonix Ignitor #1. What are you folks gapping your plugs at. I'm using autolite 45's. thanks
Banned
I'm running a stock yellow-top, and I find that 35 works better for me.
I have the flamethrower coil, so I gap mine at .042. Works fine for me. Pertronix advertises you can gap up to .050, but I think that is a little extreme.
dont go to .050 unless your running an MSD box or something equivalent. i usually with my MSD run .050 or sometimes .055. i dont notice a diff between the two though
Gone but never forgotten
The Pertronix Ignitor does nothing that points don't do, except it doesn't wear out like points. Gap them to stock. Even with a higher output coil, like the Blaster II or Flamethrower, I've found the only difference a bigger gap makes, is the plugs wear out 10 times as fast.
Now if you're using a capacitive discharge, like an MSD6, it's a different story all together.
Got new Flame Thrower 8mm wires and Pertronix 40.000 volt coil just in the other night, set the plugs at .42 . Runs great ! Although the headlights cut out on me for a couple of seconds driving home.
