So, after the installation, I spent the best part of my afternoon trying to get the IGNITOR to work on my '66 GT 289 4V. Using my research from this site, I took the time to get 12 volts via the ignition switch.....I spliced into my feed from last year's installation of the holley carb with electric choke. (Was that where I went wrong?)
In about 30 tries at cranking, it started only once and ran very roughly. I rechecked everything several times and finally connected the red Petronix wire to the BATT side of the coil. Voila! Started first try and every time after.
I haven't test driven it ( thunderstorms ) to see how it performs , but I'm confused.
So, if you survey respondents have had no problems with your coil hookup, I'll leave it alone. Thanks in advance.
