White Elephant Guy
For those of you running a 351W based engine in your 65-66 with the shock towers unmolested, do you have any pictures of the engine compartment? I've heard that they're really tight. I know they require special headers and weigh more, but there's no replacement for displacement.
Here's one. There are more at the link below.
Very nicely done car Wolfeman. Probably like many others, I've always wondered about a 351 based stroker engine in my '66, but have worried about clearance problems. Can you tell me please:
Are there any clearance problems when when the motor leans over under torque ?
I'm running a brake booster. Do you think that can still be done with the taller deck height of the 351. ?
Does that air cleaner clear a standard hood without requiring the fitment of a hood scoop ?
Any downsides to a 351 instead of a 302 in a 65/66 ?
Thanks in advance...
Yes. The headers I'm using (Hooker Super Comp) have 1 3/4" primary tubes, and there is only about 1/8" clearance between the front two tubes and the shock towers, so they have hit the towers under acceleration. This has caused a self-clearancing event to occur (small dent in the primarys). I suspect headers with 1 5/8" diameter primary tubes (Heddman) would not have any clearance problems.
I don't know.
Yes. In fact, I'm now using a 3" tall filter element with a K&N dropped base, and the Hi-po top, under a stock hood without any problems.
A few that come to mind;
You need to use engine swap headers which usually cost a bit more.
The 351 is about 60 lbs heavier.
Things are tight.
