YepIf get a cheap stethoscope to zero in the location of the noise, they are quite good at that. Most pinging noises posted here turn out to be exhaust leaks.
Where were you with that advice 30 years ago? Would’ve saved me a lot of grief Lol 🤪A 3 ft piece of old garden hose, hold up to your ear, move around in the compartment till you find the noise.
Works every time.
The one that seals all the way around....Removed header gaskets and they are bad. New problem. The header port is oval and the ports on the engine are rectangle. Doh. Which port gasket should I use?
ofcourse. But should I match the header port that is oval, or the port from engine that is rectangle. I’m guessing a rectangle to catch the corners?The one that seals all the way around....
It doesn't matter as long as there is a mating surface between the header flange and cylinder head all the way around the port of sufficient width to seal it.ofcourse. But should I match the header port that is oval, or the port from engine that is rectangle. I’m guessing a rectangle to catch the corners?
In same shop, same wife, same attitude, same love for our old Mustangs. Built shop in 79.Where were you with that advice 30 years ago? Would’ve saved me a lot of grief Lol 🤪
