replaced my intake gasket still leaking !!!!left out the cork end seals and use permatex sealer,oil gushing out back...grrrrrrrrrrrrrrrrr...try try again
I forgot to pre-lube the timing chain and fuel pump cam before gluing the timing cover back on with sealant and gaskets and bolts.... ::
Can you lube the fuel pump cam through the hole? Or, just goop up the lever on the pump itself? I don't recall any need for extra lube on the timing chain itself.
Might save you from tearing it apart.
Hey Topless!
Yeah, I thought I'd lube the fuel pump arm. The timing chain is not new and is original, so there is probably enough oily to go thru the firing procedure.
Gone but never forgetten
Use a THICK bead of high-temp silicone. The bead should be about 1/4" tall. Let it set up a couple minutes, then be sure to use 4 studs in the heads to make the intake drop straight down. After you get the rest of the bolts in and hand tight, remove the studs and put the last 4 bolts in.
Should be good for years of leak free operation.
Hehe!! You dont know me...with my luck I'll be cranking and cranking for days trying to figure out why the engine wont fire! :: Nothing will get lubed, just worn out!!! LOL!! Anyways, thats what ol Tom Monroe suggests to do for the pre fire sequence.
