AGAIN--Send pictures of the nut and END of sector. Did you torque to 125 pounds?Yes. It is torqued down but the nut is not up to the sector
If by that you mean you have applied specified torque but the nut is NOT up against the shoulder on the spline, that's good. It would not be possible to tighten properly if the nut hit the shoulder.Yes. It is torqued down but the nut is not up to the sector
No the nut will not even fully thread on to the bottom threaded section so nowhere near the shoulderIf by that you mean you have applied specified torque but the nut is NOT up against the shoulder on the spline, that's good. It would not be possible to tighten properly if the nut hit the shoulder.
WOW--Are you observant, The new nuts on these boxes are thicker than the stock. Explains the non flush situation.I thought the nut looked thick…..I need to double check mine.
What is the torque setting?No the nut will not even fully thread on to the bottom threaded section so nowhere near the shoulder
You'd be surprised what any layer of paint on either the sector or splined area of the Pitman arm will do....Makes me wonder if the Lares steering box shaft or the nut they provide are metric and not compatible with the other.
.... and some lube on the thread and face of the nut. The nut will push a lot harder with the same torque applied when lubed vs. dry.You'd be surprised what any layer of paint on either the sector or splined area of the Pitman arm will do....
The threads are standard, the nut is thicker.Makes me wonder if the Lares steering box shaft or the nut they provide are metric and not compatible with the other.
A lot of wrenching amateurs have no idea on how big a difference on the clamping force, the conditions of surfaces actually make when tighten a bolt or nut.My mind went straight in the gutter . . . .![]()
My thought is since it’s an aftermarket box, there could be bad machining of the threads on the shaft or a mis-boxed nut that could cause issue with tightening.The threads are standard, the nut is thicker.
