Mocking up the under-dash AC unit...just using it for the vents.
I had read somewhere that it mounted using existing holes under the dash, but that doesn't seem to be the case with my car.
Here's a picture with the left bracket mounted in the same hold that the under-dash light mounts too.
The unit is offset from center by 7/8". Is it supposed to be centered in the cab?
If using the existing hole on the left side, there is no holes on the right side.
There is another hole to the right of the one I'm using (don't know what it's for). But if I use that, then the unit will be offset to the right side.
What's the correct placement? Do I just center it and drill my own holes?
I think I may have a 66 unit...didn't the 65 units have the black camera case finish? I kinda like the silver face, so I'm fine with it not being 'correct'....but were the brackets different? I have a 66 dash hanging up on my wall and the holes are the same, so no difference with the car sheet metal.
