Unfortunately the last part is completely true. One of the last shops I went to left my strut rod nut loose(adjustable) and didn’t put a cotter pin in. Heard a tinkle of metal on the way to school and found all the bushings off one of the rods.Can’t help with the local alignment shop query, but can point out that you can buy really nice digital alignment tools and do it yourself.
The cost of the tools would not be much more than a shop will change for an alignment, and the results if you do it are bound to be more precise because you care. Not difficult to learn the procedure either.
To a shop it’s just another annoying old car. They’d likely just set the toe-in and charge you for a complete camber / caster / toe alignment job.
Z
There’s a small car show every Sunday so that’s a great idea to inquire about! Thanks much.well that didn't happen overnight
plenty of alignment shops that can handle classics
talk to some car club guys or folks at shows.
i bet the same 3 names will come up all day
No argument there, that’s proof. My dad has the same tires on his 69 chevelle and doesn’t carve corners… he did daily it about 30 miles for work for years and had no problems. It just depends on how good they do.All of the above. The last time that I saw wear like that was on my '75 Camaro with Goodyear tires. I wore them out by screaming them through canyon roads in Colorado. Great grip, lots of squeal.
Guess who makes Kelly tires? Yep, Goodyear. If you choose to buy a matching set for the front you may repeat the wear pattern. I would buy something different for the front and have the alignment set at the same time. I have not seen that wear pattern on BFGoodrich Radial T/As as an example of something affordable.
