I have a California 1967 Mustang Coupe 289 2V, and I'm trying to figure out how to remove the air pump and associated hoses, but can't find how to do that. There are so many hoses running around the engine bay that are in my way, covering the valve covers, etc., I thought if I removed the emissions stuff it would clean up the engine area, and I can put a nicer air cleaner over my carb, and the car might even run better.
I found what I think are all the bolts I need (below), can someone confirm the bolts and where they go?
I also know a hose runs from the oil cap on the valve cover and from the carb to the air cleaner, which I'll need to cap on the carb and get a different oil cap for the valve cover.
TFS-51400265 (qty. 2): https://www.cjponyparts.com/trick-flow-cylinder-head-emission-thermactor-plug-5-0l-5-8l/p/HW1173/
C6AZ-6052-A (qty. 8): Cylinder Head Plug - Thermactor - EACH - NOS ~ 1967 -1970 Mercury Cougar / 1967 -1970 Ford Mustang
Are there any other caps, bolts, etc. I would need to remove everything? Am I missing anything?
