Old ground I know folks but I am now completely confused! Putting a T5 into a 66', 289, with a late model bellhousing and release arm. We are converting from a C4 to a T5, so have had to replace virtually everything from the crank back. We have the Modern Driveline clutch cable system installed and we need to get the proper clutch assembly. Just got a flywheel from Summit, 157 tooth, 28 oz. imbalance, which is the "newer" 289/302 style that is drilled for differant pressure plates. So, here is my delema:
1. Which clutch/pressure plate assy should I ask for at the parts counter, (specifically which year, etc.)and is it 10.5 inch, or 10 inch?
2. I am assuming I dont need the fulcrum spacer, since I am using the "newer" release lever with "newer" T5 bellhousing and Modern Driveline cable? Is that correct?
3. If anyone has a part number of a "set" I can order from Centerforce or someone that includes the diaphram pressure plate, clutch disc, and proper pilot bearing...that would be awesome!!
I spent the last hour in the search portion, I think that is why I'm so confused? That or it really is just old age creeping up, (RATS!!). Any and all help will be appreciated all, I think I am old and stupid and just need a plain and simple "shopping list" here! TIA
