You can also use a Chrysler ignition module to fire it too. Summit sells a Chrysler high performance module for the street for $37.00. It's a lot smaller then the Duraspark. BTW did you know that the white wire on the Duraspark will make a poor mans ignition retard system? Ford uses it to retard the timing when cranking to make it easier to start.
