You can adjust it by changing the cable gear in the transmisson. Do some search I think there is a formula to find the right gear needed. FORD parts house usually carries most of the gears. But you may not be able to acheive the right reading depending on diff gear ratio and tire size.
I have a 3.00 with 235/60/15 and I could only get to 7 miles of actual, so I adjusted to 10 miles off to make it easier to estimate. 55 reading = 65 actual
