K
kbmwrs
·Guest
Okay I have a 67 with the center comsole. The garage door works fine but the PO cut the back cones off the radio shaft holes and also the console is cracked from the right radio shaft hole to the edge. Now I picked up a used center console section (where the radio and garage are located, the piece in question). Its radio shaft cones are intact, no crack either. Unfortunately the brushed aluminum(?) trim around the garage door is missing (would need to grind the tack welds off the old one and glue it on this one) and the worse thing is that at the right side bottom of this piece it has been bent out like someone tried to pry it off the dash once. It sticks out about 1/4".
I have a two shaft radio (just purchased) that I plan to install. I'd much rather install the replacement center console but do you wonderful idea guys have any way I can bend back this piece without breaking it? As you know its made of that cheap-ass pot-metal which easily cracks. Or do I just live with it out of wack slightly?
Thanks for any help.
Michael G.
Michael G.
