1 - 2 of 2 Posts
When I started my Mach after sitting for a while. The brake pedal didn't seem to have any power assist. Thinking I may have a vacuum leak I did some testing. I hooked my vacuum pump to the booster via the vacuum connection. It didn't hold a vacuum.
My question is should it? And if it should does it mean that it has to be replaced?
When you start the engine vacuum is immediately applied at the power brake booster so you should have vacuum assist. A booster that is functioning properly will even hold a vacuum for many days after shut down and provide brake assist when the brake pedal is depressed. Either the internal valves and/or diaphragm are leaking. Replace the booster with a rebuilt unit. Also depending upon booster model, you may be able to have your unit rebuilt.
1 - 2 of 2 Posts
