1 - 2 of 2 Posts
I have a Power Brake Conversion pedal setup with modified pedal support and brake pedal for an automatic car. This is one of my older versions but still functionally the same as the new ones. It has a revised pedal ratio to get the modern brake feel. I took it back on trade from a guy that upgraded to five speed pedal conversion. HE had never installed it. Add a Fox Mustang booster to it and you have POWER BRAKES on your 65-66 Mustang. It will fit automatic cars only, unless you add my cable clutch setup to it. You can use the V8 Fox booster if you are running a Shelby type export brace. Others require the 4-cylinder booster or a 80 Fairmont booster. Any Ford dual piston master cylinder will fit it, or you can use your original master cylinder. I will sell the pedal and support for $100 plus $10 to ship it in USA. [email protected] I have boosters available also for $135.
http://www.mustangsteve.com/BrakeServo1a.jpg
1 - 2 of 2 Posts
