·Hi all, new to the forum and I have a question for you right off the bat! I'm currently trying to switch my manual brakes over to power, I went down to the local Checker parts store and picked up a reman booster and bolted it in (Midland/Ross unit) the actuating rod does'nt even come close to hitting the pedal. Any ideas? As far as I can tell the only difference betweeen the Bendix and Midland unit is that one has a crimped band and the other has a bolt on band. Were there different pedal assys? The manual lists the same part #s for both power and manual. Again it has all the right mounts and everything bolts up except it doesnt reach the brake pedal. The car is a 68 Coupe. Thanks in advance for any resolution you can bring to this frustrating problem.
Ron
Ron
68 Mustang Coupe
Ron
Ron
68 Mustang Coupe
