1 - 1 of 1 Posts
http://www.mustangsteve.com/booster_bracket_mc_clutch_side.JPG This setup has it all...You get a complete setup for adding power brakes and cable clutch to your 65-66 Mustang for an outstanding package price. Uses original pedal parts, beadblasted and repainted. Includes rebuilt pedal support, modified for power brake conversion and ballbearing clutch pedal shaft, a clutch pedal modified with quadrant for cable clutch, a brake pedal modified for power brakes (includes revised pedal ratio for less pedal travel), a FORD rebuilt power brake booster, an adjustable clutch cable (same as Fox Mustang V8), an adjustable billet aluminum firewall brace/cable stop, and a brand new disc brake master cylinder. All this bolts into your Mustang and includes complete instructions. Perfect for your 5-speed conversion, while adding power brakes and a dual piston master cylinder at the same time! All that for only $525 + UPS ground shipping. Add up all the parts separately and you will see what a bargain this setup is!!! Plus, you can be confident that you are buying a well-designed, proven setup that will bolt in without problems. I have sold quite a few of these and every single purchaser was very happy with the results. No hassles of trying to fit Seller A's parts with Seller B's parts. This setup is hassle free. Feel free to email if you have questions. See all pics and details at http://www.mustangsteve.com THANKS :)
1 - 1 of 1 Posts
