A buddy posted a problem I was having with my power brakes and I have solved the problem the rod from the pedal to the booster is the wrong one the guy I got the car off of some years ago just sort of threw things together so I was in the dark about this wrong rod.Anyway the problem is found now I need help I can't find anyone that sells the correct one could someone please steer me in the right direction to find one
you might try checking with 'Booster Dewey' at Power Brake Booster Exchange: website
He might at least get you pointed in the right direction.
Do you have the wrong rod, or the wrong pedal? 69 pedal for power brakes has 5" from pedal pivot to pin. The booster has a curve at the end where it hooks to the pedal pin. The 70 pedal has 4.5" between pivot and pin and the booster has a straight rod. Boosters did not come with different length rods...
