1 - 11 of 11 Posts
Hi everyone,
I drive a '65 Mustang 289 with the original power steering system.
As I was slowly turning the steering wheel while backing out of a parking spot yesterday, I heard a pop and my steering went stiff. I can still turn, but with a lot of effort and a lot of squealing -- the type of squealing you get when you reach the furthest limit of a left or right turn, except now it happens anytime I turn the wheel. And, as I said, the steering is obviously stiffer, as if the power steering is no longer working.
I checked the engine bay and the belt was still there, and there was no fluid overflow or explosion of any kind. Everything looked normal. I checked the reservoir and there was fluid. And, yes, I'm using the correct fluid: Napa ATF 75-205.
Some background: My power steering (transmission) fluid reservoir has been leaking slowly but surely. I've been topping it off and checking it regularly, but I can confirm that I drove the car at least once a few weeks ago with NO FLUID. After filling it up though, everything seemed fine and I was driving without problems until this happened.
So, in summary, my power steering popped on a slow turn. Now it takes a lot of effort to turn and squeals loudly. What's wrong?
When you filled it, did you turn the wheel to both extremes? I believe that’s what you do to get the air out of the system when adding fluid. Maybe you have a big air bubble in your lines?
Remove belt for power steering pump and see if you can rotate it.
What happens?
Did your ram bracket break or tear away from the frame? Look under the car right behind the drivers side front wheel. Mine has broken twice and it makes a loud pop and you lose power steering.
Having torn that bracket away from the frame myself, I know the feeling. It could be the source of the initial "pop", but would not explain the squealing sound that followed.
^ What he said.
ex-Global West GM
1991-1995
Discussion Starter · #10 ·
Sorry for the late reply, but you guys were correct! The bracket that bolts to the frame rail popped off.
In any case, I ended up removing the power steering. I feel much more confident in the steering now.
And, no, the PS is not for sale ;)
Thanks for your help!
1 - 11 of 11 Posts
