I've just noticed a new leak on my PS pump. From underneath, it almost looks like the whole front pulley assembly slides into the outside case unit and the leak is where the lip of the case meets the pulley assembly. Does this make sense to anyone. Do I need to just trash the pump ? It works fine otherwise.
I put a rebuild kit in mine a few years back, and I seem to recall a big rubber o-ring which seals the unit it the place yours is leaking. Very easy to work on, anyone can do it. Don't trash your current one if that's the only problem.
Following up on what Woody said, you can get the reseal kit from NPD for under $10. A little messy when you detach the hoses, but easy job otherwise.
