1 - 2 of 2 Posts
I'm was cleaning up a 65/66 Non AC pump and noticed that this pump was always black. I did a little checking and found out that Ford had 2 different companies making them. 1. Ford Thompson Pump on the tag F in center line color Teal / Blue... 2. TRW Pump on the tag W second digit in on bottom line color Black. Is this true and if so what black did they use Gloss, Semi Gloss, Flat ? Thank you
Non - AC the black is closer to gloss than not. Probably a rattle can gloss black would be close to the original TRW integral reservoir pump finish.
Reactions: BW66
1 - 2 of 2 Posts
