I have rebuilt my pump, cylinder and valve. The wheel pulls very hard to the right. What is wrong? Are my hoses on backwards or does my valve need adjustment?
Just sounds like your valve is off center (provided everything else worked fine prior to the rebuild). Just pop off the cap on the valve and turn the nut until it returns to center both ways (helps to have the cars front end off the ground).
Jeff
If your hoses were interchanged, your steering wheel will start turning lock to lock violently as soon as you turn the wheel a little bit.
Dean T
