hey guys, im still in the middle of the engine swap right now and am having a problem w/ the bracket that the motor mount bolts to. I just need to know what type I need. The engine im using came out of a 70 two door maverick and I have the brackets, but they don't fit right. The brackets im referring to are at the bottom of the whole motor mount assembly, the piece that bolts to the frame. So if you guys have any info id appreciate it, thanks
If you need help I am only a few miles from you. Send me a PM if you would like my help.
Scott
yes...but I was looking for a way to use the mounts that I already have bolted to the engine and jus use a different bracket...Those mounts are B*tch to fit in
