41 - 50 of 50 Posts
First off I have to say your doing a great job.
I have installed the R&C MII and plan on installing the MTF kit. I figured it would be more help than not. What I have also thought about doing is adding a square tube under the cowl lip in the engine bay and run it from end to end and tie into it as well. I just read a post that showed reinforcing the door post area and outer kick panel area was a key point to stiffen up.
As for the fixed point of failure I would have to think that adding the torque boxes and frame connectors helps spread this point throughout the car more than what one would think, I could be wrong.
I have frame ties, added front torque boxes and undecided on a roll bar or not. Would like to add the flat panel and weld in it that goes behind the back seat trunk area. When I made my frame connectors I added in two 1/2 inserts into the connector so I have a strong through mounting point. Thinking of building my own X brace like the TCP one. I may even add the vert inner rockers but unsure at this point in time how far I should take it.
Discussion Starter #42
@Black Gold 380R . You'll get varying view points on the Mustang II suspension. I have installed mustang II type suspension on various mustangs. What I will say is based on experience from building my brother's 66 mustang using the mustang II suspension. His goals are almost exactly like yours, but he daily drives his. A few things I'd like to say before I give my $.02 on the debate.
  • I'd like to think all the suspension companies did their stress analysis on the suspension kits
  • All companies out there have their following/followers.
  • Some of the said companies have great success using their product in the racing world, but sometimes not all racing stuff translates to the real world
With that said here is my $.02 or just a FYI.
  • As mentioned earlier, the mustang II does add torsional stiffness, but it subtracts bending stiffness. The shock towers, export brace, monte carlo bars, etc act as a truss for the sheet metal frames. Even though some of these connections are bolted together, they do help provide bending stiffness. What you will also notice, is that none of them are flat. They have a height to them which increases bending stiffness. But making them one piece increases the stifness even more. Your example of the front subframe used on gen 1 camaros and later is not really accurate. The front suspension that more closely mimics the mustang front suspension is the 62-67 novas which will bring me to my next bullet. Ironically Hotchkiss makes down bars now that tie the upper control arms to the firewall for the Chevy crowd.
  • Definitely install the down bars from the firewall to the frame rails. This part is based from personal experience. The fender aprons were not designed to take the suspension load and/or vehicle weight cycling up and down. You will eventually start to see cracking/separation in the cowl area where the fender apron is attached as well as where the front and rear fender aprons are welded together. The time it took for the cracks to appear on my brother's car took about 7-10 years of daily driving and they progressively got worse. As a side note, many aftermarket manufactures of the Nova suspension incorporate the down bars in their kits to try and replace the strength loss from removing the shock towers.
  • I do have analysis to back this up. This is of a simply supported beam with the fixed point mimicking the firewall as an infinitely strong fix point. Similar to the mustang/nova. The first 2 pictures are the stress and deflection without the down bars. The last 2 are with. Notice how much stress and deflection decreased just by adding the down bars. Just remember, this is overly simplified. Numbers will change when you add fender aprons and cross members.
  • Even if all the companies have done their due diligence, real world is all that counts. What I haven't seen from any is daily driving experience for an extended period of time which I think is the key. Even with the stress analysis I did, there is no guarantee the down bars will eliminate cracking, or if my brother's particular instance was even a one off, but I do have a better understanding of how it could happen.
Conclusion - In my opinion add as much back that you can. Down bars, torque boxes, etc. I'd tie the down bars across to mimic a monte carlo bar and even tie that back into the firewall to mimic the export brace. Just FYI, I too have eliminated my shock towers on my coyote swapped 67 cougar, but I have added the aforementioned parts. I wanted a stiff chassis because I wanted the car to handle. If I had to do it all over again, I'd notch my shock towers and mimic a boss 429 setup to fit the coyote in. Everything is my opinion based on my personal experience and just wanted to give you my insight. You're doing a great job on the car.
WOW!!! Thank you 1bad68cat! This is exactly the type of post/response I was hoping to get when I started my build thread. Your feedback, experience and point of view is invaluable. I have ordered the torque boxes and the MTF frame stiffeners. I know I could do more, but these items WILL be added and I will continue to analyze my build to see if I can make it better.
I do understand everyone will have a point of view and an opinion on the execution of my build. I'm okay with all feedback and points of view as long as people are respectful about it. So far everyone has been very respectful and providing both positive and negative points of view on my build. I think the feedback is awesome as it gives me other things to think about or provides me with another point of view that I may not have thought of.
Thank you for your compliments on my build and thank you for your help. It's appreciated more than you know sir!
Thank you RTM! Really appreciate you taking the time to view my build thread and provide insight on what you are doing and what you have purchased and installed on your car.
Really appreciate you guys. I've had my 65 since 1989, but have never done any modifications to this level. So, all feedback is welcomed and appreciated!!!
Thank you !!! (y)
Thank you !!! (y)
@Black Gold 380R , just to give you an idea of what I did to my brother's latest 66 mustang and my 67 cougar. You'll see where I tie the down bars to the frame and the firewall. These points to me are crucial because the mounting point at the firewall now transmits the loads into the B-pillar and the frame mount is as close to the upper control arm as I could get it creating less of a bending moment/effect.
762050
762052
Discussion Starter #44
As always, thank you 1bad68cat. I appreciate the pictures and showing me what you did. Problem is I'm just doing this in my garage. My only advanced tools are my air compressor/air tools and my welder. I do not have access to a tube bender in order to make those tubes. So, I'm kind of at the mercy of whichever company has decided to make this stuff. This is why I went with the MTF frame stiffeners kit.
My car is mainly going to be a weekend cruiser/car show participant. So, based on the information you have provided I think my car will hold up, with the understanding it could be better.
Thanks again. You have been a great help!
No problem @Black Gold 380R. My tool arsenal is the same as yours. I too just have a garage. Wish I could have a small shop though, but don't we all. What I did for the tubing was buy from the local metal supply store and found a shop that could bend the tubing for me. Cost me $85 total ($35 material and $50 labor) and I just provided the shop with a template made out of welding wire to bend the tube to.
Discussion Starter #46 (Edited)
Well, I left off with trying to clean up the outer firewall area in order to prep it for my torque box installation. Well, that's what I got completed this weekend.
Some of you may be thinking that's all I got done in two days. LOL, well all I can say is I'm new to this and I take a methodical approach to the job. I need to make sure I cut the metal properly in order to make sure it fits snug and correct.
Remember I'm a rookie when it comes to metal work. So, I'm going slow and steady and will get there eventually LOL.
Torque boxes come welded together. I seen a guy on YouTube (Jo Daddy's garage) and he separated the boxes prior to install. After doing this I don't see how these can be installed without separating them.
762672
762673
Got the outer firewall area all cleaned up. Man, that undercoating is a B!T(# to get off LOL.
762674
Got the area sprayed with weld thru primer to protect the metal.
762675
Got the backing plate trimmed and mocked up.
762676
Got the backing plate welded in place and covered with weld thru primer.
762678
Got the outer box trimmed and mocked up.
762679
Outer box welded into place.
762680
It was the same process for the passenger side, so here is a picture of the final result.
762681
Discussion Starter #47
Okay everyone,
Made some good progress this weekend. Got my firewall and rear fender aprons finished by smoothing out the remaining holes I wanted filled on Saturday.
Fender Apron holes.
763343
763344
763345
Wire harness pass through on fire wall I'm moving.
763346
763347
I decided instead of trying to cut circles/plugs I would just cut out squares as they are easier for me to work with.
763348
The patches are made, welded in and ground smooth.
763349
763350
763351
Discussion Starter #48
Then on Sunday I decided to start mudding the firewall. Again, this is the first time I have attempted body work, so it will probably go slow and l'll probably have to do it a few times in order to get it straight LOL.
Based on my research this is what I'm doing:
I'm using a fiberglass filler to fill in areas I feel are a little deeper than I'm comfortable with. I feel the fiberglass filler will be less susceptible to cracking than regular body filler. Then I'm using body filler to smooth out the rest of the area. Then I'm using 40 grit to knock everything down. Then I'm using 80 grit to shape it. Then I'm using 180 to finalize the area and to prep it for a 2K primer.
This was my progress on Sunday.
(NOTE: I'm not plugging this product. I'm just showing what I'm using).
This is the fiberglass filler I'm using.
763352
This is the body filler I'm using.
763353
Here is the firewall after all the metal work. You will notice on the top portion of the firewall, where I had to weld, is not the smoothest. Those are the areas I feel I need to use fiberglass filler instead of body filler.
763354
Here is my initial skim. The areas in green are fiberglass and the tan area is normal body filler.
763355
My initial knock down with 40 grit. Although this process does go quick, when you have to sand and sand and sand it gets tiering LOL.
763356
Another skim of body filler as low spots were showing.
763357
I put a little more body filler on the passenger side of the firewall and worked it all the way through on the entire firewall (i.e. 40, 80 then 180 grit). This is where I stopped Sunday afternoon as I was tired from all the sanding. I still have way more body work to do, but it's a start :).
763358
Discussion Starter #49
I was applying the body filler and trying to fill in low spots, but when I would sand it down I could still feel a transition from body filer to bare metal. So, I was watching Bitchin Rides and noticed that even though their metal work is pretty straight they skim "ALL" the metal and then shape the body filler.
Once I seen that I tried it myself. I'm not as good as they are, but noticed their technique worked better for me. So, I'm happy with how the body work is coming out.
This is them working on an F-100. They even removed the front section to get better access the the firewall area. This is why I started on the body work before completing the engine bay. I didn't want to be climbing in and out to do body work. Seems to be working so far.
764093
764094
764095
764096
Discussion Starter #50
Well, just like metal work (which is obviously not finished LOL), body work is the same process. Apply body filler, sand, shape and smooth and sand some more LOL.
This weekend I got the top portion of the firewall completed. Started working on the bottom part of the firewall (transmission tunnel) and the frame rails.
Still got a long way to go, but I am making progress every weekend.
This is where I started back on the project.
764097
Doing work on the rear drivers side apron.
764098
Had some low spots and needed a little more filler.
764099
Driver's side rear apron finished up.
764100
This is actually the second coat of filler in the transmission tunnel.
764101
This is the finished tunnel. I know it is not perfect, but this is not a show car and you really won't see this once the car is back together. So, I'm good with this. Trying to focus more and areas that will be seen.
764102
Got started on the driver's side frame rail.
764103
Rear portion of driver's side frame rail about 90%.
764104
Got started on the passenger side frame rail. Initial skim and knock down with 40 grit.
764105
And this is where I ended this weekend. Man, now I know why it is so expensive to have a car built. This is a "TON" of work. However, it will be well worth it when it's all said and done......
764106
41 - 50 of 50 Posts
