where is the proportioning valve located on 65/66 mustang with disc brakes can't find it on the 66 i have thanks bob
Does the car have disc brakes?
If yes, follwing the brake lines from the front wheels backward, and from the master cylinder outward. You should run into 2 parts. One is a brass piece, about 1 1/4" long, with the brake lines going into and out of it. That is the distribution block. The other part is the proportioning valve, looks like a roll, about 2" long, about 1" in diameter, if it is original.
looked good nothing there lines look original, was the valve mounted to a bracket, anyone have a picture thanks Bob
