Do you have battery voltage at the "A" terminal on your dummy regulator?
Do you have battery voltage at the "A" terminal on your dummy regulator?-original BAT wire from car is taped off and not being used
Will check tomorrow after the rain, I am assuming that the “A” terminal runs parallel with wire that was previously connected to the alternators BAT meaning I need to connect it to the B+ terminal on the alternator? I saw someone did that in this thread and it worked for him - thanks for the late replyDo you have battery voltage at the "A" terminal on your dummy regulator?
See the splice in the original harness. The "output wire" from the alternator goes in 4 separate directions (regulator, inside the passenger compartment for the "feeds", the ammeter and to the battery, via the common lug on the solenoid. Lacking these splices in the replacement harness, wires need to go to a common point. In the case of the output wire these can be picked up at the BAT terminal on the alternator or the common lug on the solenoid. It doesn't matter which, other than for the ammeter.... The ammeter is a "special animal" as it's a shunt type and both wires going to the ammeter are exactly equal in length and the wire spliced to the alternator output is located at a point that effectively "zeroes" the gauge.Will check tomorrow after the rain, I am assuming that the “A” terminal runs parallel with wire that was previously connected to the alternators BAT meaning I need to connect it to the B+ terminal on the alternator? I saw someone did that in this thread and it worked for him - thanks for the late reply
Brilliant reply - will solder and add a ring connector and put it with the B+ terminal - should solve the issue - the PA instructions don’t mention this wire so it was a bit confusing and I was worried about high amps traveling through it but I suppose the 4G battery cable with fuse takes care of that!See the splice in the original harness. The "output wire" from the alternator goes in 4 separate directions (regulator, inside the passenger compartment for the "feeds", the ammeter and to the battery, via the common lug on the solenoid. Lacking these splices in the replacement harness, wires need to go to a common point. In the case of the output wire these can be picked up at the BAT terminal on the alternator or the common lug on the solenoid. It doesn't matter which, other than for the ammeter.... The ammeter is a "special animal" as it's a shunt type and both wires going to the ammeter are exactly equal in length and the wire spliced to the alternator output is located at a point that effectively "zeroes" the gauge.
Check the continuity between the FLD post on the alternator and the "F" terminal in the regulator plug. You should have less than 0.1 Ohm. I'm not familiar with the color codes used by the PA Performance harness, but there needs to be a direct connection between the regulator "F" and the alternator FLD.Yellow or ”A” at VR is getting 12V with ignition on or off = Just the way it should be.
Green/Red “S” is getting 12V with ignition ON = Just the way it should be.
Orange ”F” is not showing any voltage regardless of ignition on or off (this is the wire that is attached to the PA Performance green/red wire on the harness) Not the way it should be.
I did test resistant a few days ago and can confirm the red/green or field from the alternator is the one going to F on the VR - will check again for continuity. I do have my electronic choke spliced into that line, wonder if that’s something to do with it? With the ignition on, the electronic choke is showing 12V.Check the continuity between the FLD post on the alternator and the "F" terminal in the regulator plug. You should have less than 0.1 Ohm. I'm not familiar with the color codes used by the PA Performance harness, but there needs to be a direct connection between the regulator "F" and the alternator FLD.
Choke should NOT be connected to the Field wire. Power in the Field wire, controlled by the regulator, tells the alternator to charge.I did test resistant a few days ago and can confirm the red/green or field from the alternator is the one going to F on the VR - will check again for continuity. I do have my electronic choke spliced into that line, wonder if that’s something to do with it? With the ignition on, the electronic choke is showing 12V.
maybe I should move the electronic choke to the stator wire (PA suggest this)
Excellent, will change this, what interesting is that the end of the electronic choke is reading 12v but the end of the F from isn't and they are spliced together - this brings be to believe there is something happening between the connector and the harness VR connector, going to track it down today now that the rain stopped, change the ground and the choke. Appreciate you again!Choke should NOT be connected to the Field wire. Power in the Field wire, controlled by the regulator, tells the alternator to charge.
Toss in a new set of plugs but, before you do, check dwell while cranking...Jumped to my other car, got battery voltage at 13.3 - still won't run, tried starter fluid in the carb and nothing. I am so beyond clueless as to what could be going on - double checked all grounds and wiring. I also tried jumping the electronic choke straight to 12v just while cranking to see if there was an issue there and no luck. I am honestly at the point of putting the old alternator back in and seeing if it starts. I don't understand why it wouldn't start considering changing the alternator shouldn't affect starting -
Getting some white smoke out of the exhaust and it smells like gas specifically. I could only assume it's beyond flooded at this point and maybe I just need to let it sit for a few days. Any help is much appreciated - all this to stop the lights from pulsing (I'm over here kicking myself haha)
