·in the past I have totally assembled the front end 'chunk' with the grille and everything attached to where all i had to do was install the 4 bolts on each headlight bucket, the 2 bolts at the top of the grille and the little 5/16" screw at the bottom of the grille support. only problem with this is you are taking a crap-shoot at the fit.
Best thing to do is put the headlight buckets on the lower grill support and start the screws. Put it up to the car and tighten everything down to where it fits. Then, install the grill, install the grill mouldings and then the horse/coral with bars already attached. If the bars are crooked you can loosen the bar screw with a wrench and get it right. You need to walk about 15-20 foot away from the car to check the fit and alignment of the front end parts.
Charles Turner
MCA Gold Card Judge(64.5-65, 66)
'65 Fastback
'00 GT Conv, triple black
Check out my 65 [color:blue]fastback!</font color=blue>
Charles Turner
'65 Fastback
